Heading into the big city to get an egt guage and probe. Not quite sure where to mount the guage. Every indash guage location is filled in my dash. Was thinking about putting it in the upper console above the windshield next to the speaker. Or is there a better way? Also where should the probe go? Ive welded bungs on in the past but the metal of the doser injector housing looks thick enough to drill and tap direct. I would drill just ahead of the spray of the doser. Is that the way to go or is there a better way? Thanks in advance!
Universal 2 gauge pod from GlowShift.
Die grinder with a flapper wheel along with some patience to slowly form it to fit the steering column of either a KW or Pete will also give you this look...
Or, if your willing to pay the shipping, I'll send you this prefitted one! (Not the gauges, just the pod...)
I have bought the three gauge version, and I'm going to add a second exhaust manifold heat soak pyro like Rawze, to the downstream exhaust gas one from the pic.
Two pyro's with a boost gauge in a fancy pod adds 310hp for the win, lol
On my prostar I was lucky and had a spot open. I just had to bore it out a little bigger and punch a new hole for my boost gauge.
I'm going to add one to my peterbilt but have the same problem you have with no room but im just going to remove one of thos useless gauges like fuel filter restriction. I change my filter every service so it's a waste.
(09-10-2017 )Brock Wrote: [ -> ]On my prostar I was lucky and had a spot open. I just had to bore it out a little bigger and punch a new hole for my boost gauge.
Your Pete has the same steering column as my KW, did you see where I put mine?
Nobody has spoke up for it, you can have the pod if you want it, I'm changing to a 3 gauge next time I get home...
