12-21-2017,
12-21-2017,
(12-21-2017 )Rawze Wrote: [ -> ]that is pretty dirty.
Yes sir it is. clearly in need of cleaning. Did not see any cracks in face of doc. Very happy about that.
12-21-2017,
Does that filter just slide out of the outer casing? Can ya snap some pics of the can when you do get the filter out and a brief description of how to do it without bustin anything? And what about the doc? Any pics would sure be helpful.Thanks ;-)
12-21-2017,
(12-21-2017 )schISM Wrote: [ -> ]Does that filter just slide out of the outer casing? Can ya snap some pics of the can when you do get the filter out and a brief description of how to do it without bustin anything? And what about the doc? Any pics would sure be helpful.Thanks ;-)
it opens in 2 sections... the DOC and the DPF. - You take both cannisters to get baked on a machine for a few hundred bucks. - The elements in the middle is welded in place.
01-01-2018,
Ok
Another problem. Had the can cleaned, and will post results shortly. Drove the truck 100mi, and this shows up
01-01-2018,
01-01-2018,
01-01-2018,
Also installed doser. Is their a procedure in insite, that needs to be done for the new doser . [/php]already did reset for the can after installed. Thanks for help in advance.
01-01-2018,
DPF differential sensor getting stuck in range. Saw that last week when we had a -46°C windchill. Moved it into shop and did forced regen and it was fine.
