01-01-2018,
01-01-2018,
[/quote]
Make sure your regen inhibit switch is not inhibiting the regen cycle.
[/quote]
Ok
[/quote]
Ok
01-01-2018,
Just learned I need to reset ecm, as well as the cleaned can when installed. I did the ecm reset, but not the can reset.
Doing forced regen, then do reset on can. Is this correct?
01-01-2018,
01-01-2018,
01-02-2018,
how about fixing your crank case pressure switch. That can throw things off on some trucks because it is used as compare against the altitude sensor on some calibrations.
01-02-2018,
(01-02-2018 )Rawze Wrote: [ -> ]how about fixing your crank case pressure switch. That can throw things off on some trucks because it is used as compare against the altitude sensor on some calibrations.
I replaced the cc pressure switch, and have had no code since then.
01-02-2018,
[attachment=3403]
Thought this might help.
01-04-2018,
Ok,
Went 950 miles since reset on ecm and can and the DPF light is screaming again...
Did a forced regen, and sure getting tired of this. Also have fault code 2777, which points to a problem involving the inhibit switch. The inhibit switch will not allow me to do a forced regen, so I have utilize Insite to complete the task. Insite says something about ecm programming for the inhibit switch, yet I had ecm flashed to the correct av10046. I'm thinking maybe I have a bad inhibit switch on the dash, since I can not do a forced regen when pressing the rocker switch.
Thx in advance
Thx in advance
