2016 KW T680
Where I can find the specific torque for all the components on an ISX CM2350 ?
Any help will be appreciate.
(07-28-2019 )OTR48 Wrote: [ -> ]2016 KW T680
Quickserve, Cummins offers it for free. Register your truck and get all of the info you need. You will need your EIN off of the motor. Engine Identification Number. It is on the driver side of the valve cover of your motor.
(07-28-2019 )Waterloo Wrote: [ -> ] (07-28-2019 )OTR48 Wrote: [ -> ]2016 KW T680
Well well well knowledge it is power.... Thank you very much that is exactly what I was looking for !
What is the importance of having the correct torque?
(07-28-2019 )david24 Wrote: [ -> ]What is the importance of having the correct torque?
"Both under torquing and over torquing a bolt can have a catastrophic failure, therefore it is important to tighten each bolt or nut to the manufacturers specified values."
