|  Specific torque CM2350  |
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #1 | |||
| Specific torque CM2350  2016 KW T680 Where I can find the specific torque for all the components on an ISX CM2350 ? Any help will be appreciate. | |||
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #2 | |||
| RE: Specific torque CM2350 (07-28-2019 )OTR48 Wrote: 2016 KW T680 Quickserve, Cummins offers it for free. Register your truck and get all of the info you need. You will need your EIN off of the motor. Engine Identification Number. It is on the driver side of the valve cover of your motor. | |||
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #3 | |||
| RE: Specific torque CM2350 (07-28-2019 )Waterloo Wrote:(07-28-2019 )OTR48 Wrote: 2016 KW T680 Well well well knowledge it is power.... Thank you very much that is exactly what I was looking for ! | |||
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #4 | |||
| RE: Specific torque CM2350  What is the importance of having the correct torque?  | |||
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #5 | |||
| RE: Specific torque CM2350 | |||
|  07-28-2019, (Subject: Specific torque CM2350 )  Post: #6 | |||
| RE: Specific torque CM2350  Thanks for that  | |||
