11-05-2020,
11-05-2020,
here ya go...
11-06-2020,
(11-05-2020 )Rawze Wrote: [ -> ]here ya go...
Thanks, Is there a way to determine which injector is leaking? Replaced fuel rail relief valve, new fuel pump about 8 months ago, the problem started first trip out after rebuild, gives low fuel rail psi code only when pulling a hill, so im guessing its an injector or injector connecting tube, which were not replaced in the rebuild process...
11-06-2020,
Go to quickserve.com and register your esn# then you can access all this information for free.
11-06-2020,
(11-06-2020 )tree98 Wrote: [ -> ]Go to quickserve.com and register your esn# then you can access all this information for free.
I've done that, but couldnt find anything about isolating bad injector, i must have missed it, i"ll read over it again.
11-07-2020,
