CM2350 injector leakdown test
11-05-2020, (Subject: CM2350 injector leakdown test )
Is there a video for leakdown test on cm2350? I can only find the ones for 871. Thanks
RE: CM2350 injector leakdown test
here ya go...
 Thanks given by: redbeard , eggtrucks
11-06-2020, (Subject: CM2350 injector leakdown test )
(11-05-2020 )Rawze Wrote:  here ya go...
Thanks, Is there a way to determine which injector is leaking? Replaced fuel rail relief valve, new fuel pump about 8 months ago, the problem started first trip out after rebuild, gives low fuel rail psi code only when pulling a hill, so im guessing its an injector or injector connecting tube, which were not replaced in the rebuild process...
Go to quickserve.com and register your esn# then you can access all this information for free.
(11-06-2020 )tree98 Wrote:  Go to quickserve.com and register your esn# then you can access all this information for free.
I've done that, but couldnt find anything about isolating bad injector, i must have missed it, i"ll read over it again.
11-07-2020, (Subject: CM2350 injector leakdown test )
This should help
http://rawze.com/forums/showthread.php?tid=6707
