Just did 2 injectors ran2 days now skipping
01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping )
Post: #19
RE: Just did 2 injectors ran2 days now skipping
(01-01-2017 )Rawze Wrote:  You need to keep in mind that it can take up to 10 minutes+ of running before it runs smooth again after having anything in the fuel system apart. I hope you let it run for a good 10 minutes before making that determination.
Yep i ran it for close ti 1/2 hr and brought it up to temp the reason i determened it was a bad harness was when i moved the harness it either ran better or worse and when i changed it out for the old one it immediately ran great and with no smoke....
