| Questions about tappets and barrel valve |
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #1 | |||
| Questions about tappets and barrel valve Hey everyone I replaced tappets ,pump,barrel etc . I have been getting 559 code which I did post earlier in the posts. I went ahead and pulled the head back off the pump to check the head. This is what I found. The tappets are fine cam in the pump is good. The barrel valve and plungers were like this when I took them off. | |||
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #2 | |||
| RE: Questions about tappets and barrel valve Yea that's a problem. The pump needs a whole new head, the check valve inside it is bad. . | |||
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #3 | |||
| RE: Questions about tappets and barrel valve | |||
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #4 | |||
| RE: Questions about tappets and barrel valve Nope, you have to buy the whole head | |||
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #5 | |||
| 12-23-2023, (Subject: Questions about tappets and barrel valve ) Post: #6 | |||
| RE: Questions about tappets and barrel valve Genuine cummins only | |||
| 12-24-2023, (Subject: Questions about tappets and barrel valve ) Post: #7 | |||
| RE: Questions about tappets and barrel valve Here is a little insight on what Tree is talking about...check post #23: https://rawze.com/forums/showthread.php?tid=7266&page=3 I did this a couple years back. You can read the whole thread if you'd like, but post #26 explains the parts list I used.... https://rawze.com/forums/showthread.php?tid=7266&page=3 | |||
