visor lights wont come on
04-01-2024, (Subject: visor lights wont come on )
All markers lights come on expect the all 5 on visor. I tested it with new lights still nothing. I tested wire with tester, not getting any current. Can it be a fuse? Isn't it just one fuse for all marker lights? which means if it was blown no marker lights would come on?
see attached images
Image(s)
./uploads/202404/post_6775_1712016015_e896d727c24e15fdac918791fad69510.jpg
RE: visor lights wont come on
might be in the courtesy light circuit?.
have you unplugged all the batteries for the entire truck for 30 mins and re-connected them to fully reset the cabin controller?.
04-02-2024, (Subject: visor lights wont come on )
(04-01-2024 )Rawze Wrote:  might be in the courtesy light circuit?.
well i never leave the batteries connected
Is there anything else i can do or check?
Post the VIN aka serial number. If this is a 9000 series there is no body computer. There is a relay and a fuse on that circuit somewhere. Look for a blown fuse. This is a public link to my best guess on your wiring diagrams.
https://www.internationaltrucks.com/-/me...DF080F13C6
You may have to cut and paste the link. IIRC the relays and fuses are behind the dash panel on the passenger side on a 9000 series. I don't see a lot of those.
 Thanks given by: 3406E
xxxxx
Here is what I have for a wiring diagram for that vin.
{link removed by rawze: either request it as a PM message, or post an official link from he document/vehicle maker}
(04-02-2024 )3406E Wrote:  year 2005 vin:2hschapr05c000328
Your unit is older than what is on the free Navistar site. I sent you an EMail and a PM with a link to the manual you need. I don't think the link is allowed on here. Download and save it. The link is only good for 72 hours. Good luck.
(04-02-2024 )windowrattler Wrote:  Here is what I have for a wiring diagram for that vin.
I know better. My bad. Sent a PM.
