I just bought one from Napa for $275. I like it because its white and you can see the coolant in the tank. Good for if your oil cooler decides to spit or fuel gets into the coolant. I tried to Line X my old tank.....fail.
(10-15-2016 )preacherboy24 Wrote: [ -> ]I just bought one from Napa for $275. I like it because its white and you can see the coolant in the tank. Good for if your oil cooler decides to spit or fuel gets into the coolant. I tried to Line X my old tank.....fail.
I have had guys over here who have used jb-weld, fuel tank repair epoxy, 2-part epoxy, and about 5 or 6 other products. None seem to work well for very long. It is damn near impossible to fix one with epoxy etc. as oil leaches out of the plastic and makes it not stick. The proper solution is to grind out the crack and re-weld it.
I have welded a few and patched them, using a heat gun to soften the area + and big soldering iron or plastic welder.
I have welded up my bumper and rad tanks, and all things plastic and it works quite well once you get the hang of it.
mine cracked on the road by the sensor.. (international prostar)
I went to home depot and got Marine Adhesive Sealant 5200 by 3M ($15). Made it home ok but it cost me nearly $600 for a new tank from International.
But on my second truck, i ordered it online. same product for about $200. I've realized that many items International sales, they just mark it up 2 or 3 times the price. especially Bendix or cummins parts.
It took me a while but I finally found a place that works with AutoMan parts and most of the time when their warehouse doesn't have the part in stock, they order it and I go pick it up from Automan directly. I've noticed every stealership truck picking up parts from them as I wait for my parts. kinda sad.
