I have a 2012 Pete 386 with an ISX15 CM2250
With this truck I experience the steering wheel lock up. It's worse when the truck is loaded. You get maybe a whole rotation of the steering wheel and then, at pretty much the worst time, it locks up. You can steer back the other direction, but if you want to keep turning through the "lock up" you have to really force the issue.
Has anyone else experienced this?
I'm going to flush the fluid, change the filter and bleed the system. Hopefully that won't be a waste of time. Any help is greatly appreciated. Thnx in advance.
(09-21-2017 )indian_richard Wrote: [ -> ]I have a 2012 Pete 386 with an ISX15 CM2250
Have you checked the u-joints in your steering shaft?
I had this problem on my 2011 Volvo when it was less than a year old. I found if I went slow and smooth it wasn't too bad but only "locked" up when I tried to go too fast. In my case it was a bad steering box which had to be replaced and I've had no problems with it since.
We've had a few lock up steering issues on some low mileage Cascadia's in our fleet. Turned out to be the steering box. It was difficult to duplicate as it would rarely happen. But as kryten said, it would happen more frequently when trying to turn the wheel quickly. If the driver turned the wheel slowly, it wouldn't happen. We got the steering boxes replaced and the problems went away.
My '09 386 ( 533k on it ) just recently had the same problem. It turned out to be a weak power steering pump. After installing a new one, my problem went away.
Steering box, steering wheel shaft u-joint or the pump. I went through this on my ProStar, I replaced the steering shaft as it was getting up there, that helped. Then it was getting worse, to the point of locking up, I replaced the pump, problem went away. If it is locking up like you state, I would lean towards the steering gear box, especially if it just suddenly started doing this without warning. If gradually getting worse, and then locking up I would look at the shaft and or pump.
When was the last time you flushed the power steering system and replaced the filter? I guess that would be my first attempt to fix, as it is the least expensive of the above.
(09-21-2017 )big_roy Wrote: [ -> ] (09-21-2017 )indian_richard Wrote: [ -> ]I have a 2012 Pete 386 with an ISX15 CM2250
The u joints are like new. They're not loose
Check the bearing in the steering column.
(09-22-2017 )Waterloo Wrote: [ -> ]Steering box, steering wheel shaft u-joint or the pump. I went through this on my ProStar, I replaced the steering shaft as it was getting up there, that helped. Then it was getting worse, to the point of locking up, I replaced the pump, problem went away. If it is locking up like you state, I would lean towards the steering gear box, especially if it just suddenly started doing this without warning. If gradually getting worse, and then locking up I would look at the shaft and or pump.
I haven't ever flushed the power steering fluid. The truck has done this for a while now and it hasn't gotten worse over time yet.
