Takes 6-7 revelations to fire. Once started it rough idles the have to bring rpm up to 1000 then hold for 10 sec .Once that's held for 10 sec the rpm raises on it self to 1100rm. Let it idle at 600 after and it's fine.
Sometimes I will get to a stop sign or a light and it'll buck like half the motor isn't there. I'll have to bring it up too 1000 rpm again let it sit and let go of peddle and it's ok again. If I try to run at a green light after I sat on red and it's acting up. It'll puff black smoke.:oh:
(05-13-2018 )Bryanluster1 Wrote: [ -> ]Takes 6-7 revelations to fire. Once started it rough idles the have to bring rpm up to 1000 then hold for 10 sec .Once that's held for 10 sec the rpm raises on it self to 1100rm. Let it idle at 600 after and it's fine.
Really need help on this
more info! Codes? Which isx?
How long has it been doing it? How many miles on the engine? Have you tried anything to fix it?
What model engine? truck? year? miles?
when did it start? some history?
We don't have truck E.S.P.
04 isx. He started this story in the gossip box.
Without having insite hooked up It sounds like you have an injector bad causing an entire bank to get thrown off. Make sure your tanks and fuel filters are clean, no leaks in fuel lines, No bubbles in davco. Then id warm up the engine, drain the davco and refill with sea foam, restart run for about a minute kill it and let sit for an hr or so. If you have insite check codes and run a cutout test after u get done cleaning. Try running one bank at a time and try running on each cylinder by itself.
Sounds like an injector. But also check the metering and timing actuators. Physically pull them off and pull them apart and check them. Rawze has instructions on here for checking them.
I don't know about using sea-foam on your engine. Thats a $20000 gamble on if your gonna burn something or break something with pre-ignition. Plus maybe dislodging a possible obstruction or gum and then ramming it thru the fuel system and ultimately in to the injectors.
If you suspect an obstruction its always better to search for it thru process of elimination then clean it out off of the truck, than to try and dissolve it and force the gunk thru.
I can assure you sea foam isnt gonna destroy the engine. Its made for both gas and diesel. I personally would much rather spend 10 bucks on an injector cleaner than spend hrs tearing down actuators, cleaning the mounting surfaces and replacing them steel seals. Especially if there wasnt a thing wrong with em. If cleaner dont work then move on to actuators and injectors.
