10-25-2018,
Hello, I’m new to this group. Little bit about myself worked as a diesel tech for 5-6 years then about 2 years ago god my CDL and started car hauling. This week ran across a really good deal on a truck I really couldnt pass up. Got a 99 Volvo 770 with a Signature 600 and a bad auto 10-speed. Currently in the process of putting a 13 in there. I do all my own work. The truck has 773k original miles on it. It stood for over 4 years at a storage yard. I want to make the truck reliable so my plan is to
- Install AMSOIL bypass.
- Replace oil pump (shim it) + rod and main bearings.
- Valve adjust (clean all the oil passages)
- Install boost gauge + pyro.
- FASS lift pump.
Is there anything else you guys would recommend doing?
- FASS lift pump.
