Just bought my first ISX |
10-25-2018, (Subject: Just bought my first ISX ) Post: #1 | |||
Just bought my first ISX Hello, I’m new to this group. Little bit about myself worked as a diesel tech for 5-6 years then about 2 years ago god my CDL and started car hauling. This week ran across a really good deal on a truck I really couldnt pass up. Got a 99 Volvo 770 with a Signature 600 and a bad auto 10-speed. Currently in the process of putting a 13 in there. I do all my own work. The truck has 773k original miles on it. It stood for over 4 years at a storage yard. I want to make the truck reliable so my plan is to - Install AMSOIL bypass. - Replace oil pump (shim it) + rod and main bearings. - Valve adjust (clean all the oil passages) - Install boost gauge + pyro. - FASS lift pump. Is there anything else you guys would recommend doing? | |||
10-25-2018, (Subject: Just bought my first ISX ) Post: #2 | |||
RE: Just bought my first ISX the FASs lift pump is not going to do anything for it, just letting you know. Total waste of money unless you have a special need of some sort. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
