(12-09-2018 )marek4792 Wrote: [ -> ]Stupid question but did they update the injector code from the injector to ecm when they did injectors?
I told them too. Got told it wasn't needed and I told them it was needed. I have no idea if they listened.
Not needed? Run fast and far from that butcher.
Today the Truck is running great.pressures are normal and injectors are doing what they are supposed to do.completely night and day from,last night. A cummins guy told me it could be the fuel pump solenoid that's sticking.
(12-09-2018 )Nilao Wrote: [ -> ]Not needed? Run fast and far from that butcher.
I did
Picked up,new fuel pump actuator, pressure sensor, and relief valve.cummins guy said to try this. Hope it works
(12-12-2018 )Tamip Wrote: [ -> ]Picked up,new fuel pump actuator, pressure sensor, and relief valve.cummins guy said to try this. Hope it works
Please keep us posted its nice to know what the "fix" was.
Changed out the fuel pump actuator, fuel pressure sensor, and high pressure relief valve. That didn't fix anything. So I went on my own and got the engine harness. Changed it out and so far it's running very well. Time will tell if that was the issue.
Spoke too soon it's doing same shi#t again
(12-20-2018 )Tamip Wrote: [ -> ]Spoke too soon it's doing same shi#t again
Same symptoms? fuel in oil? white smoke?
