03-12-2019,
Pages: 1 2
03-12-2019,
cut out the bung, weld a plate over the hole, then weld in a new bung?
next time you need to remove an exhaust clamp or xhaust sensor, heat it up with a torch until it glows nice and red all the way through it before turning the fitting. Just a suggestion.
always use Anti-sieze when re-installing to prevent those kind of problems.
03-12-2019,
Where do i get new bung? Pete dealership told me i cant purchase only that piece...
03-12-2019,
(03-12-2019 )eggtrucks Wrote: [ -> ]Where do i get new bung? Pete dealership told me i cant purchase only that piece...
then I would find a pipe fitting at home depot and make an adapter of some sort.
03-12-2019,
I'm a firm believer in the saying where there's a will there's a way. A good radiator shop sjoild be able to braze a brass fitting in. A weld shop with a decent welder could install a piece of barstock and drill n tap it for you.
03-12-2019,
(03-12-2019 )Nilao Wrote: [ -> ]I'm a firm believer in the saying where there's a will there's a way. A good radiator shop sjoild be able to braze a brass fitting in. A weld shop with a decent welder could install a piece of barstock and drill n tap it for you.Brass and brazing will fail with DPF temperature.
03-14-2019,
The place that baked it for me had new one for $40...will be more careful with sensor removal now
03-16-2019,
Google DPF bung repair. They are everywhere. Another tip, after you heat it red hot pour cold water on on it. Use a line wrench. Overkill but I have a set of sockets that are like line wrenchs. Same socket idea used years ago on PLN enginges.
03-16-2019,
(03-16-2019 )DVT873 Wrote: [ -> ]Google DPF bung repair. They are everywhere. Another tip, after you heat it red hot pour cold water on on it. Use a line wrench. Overkill but I have a set of sockets that are like line wrenchs. Same socket idea used years ago on PLN enginges.Wouldn’t pouring cold water on it shrink it and make it brittle. I would think heat the bung. Concentrate the heat on the bung. Then when you start to see redness that’s hot enough. The expansion in the bung should release. There’s a lot of ways to skin a cat though I guess.
Pages: 1 2
