05-25-2019,
I know that there is a lot of other posts/threads about these kinds of issues and I have read through a bunch of them but hoping that something might stick out with what I have going on and where someone can help
Friday on I 90 in Idaho just west of the Idaho Montana border have a 2015 389 Peterbilt with the Cm2350
Started down the mountain by the small town of Mullan my truck got a check engine light and died I pulled over in a white spot on the highway where I still sit I would’ve 559 code I was finally able to get some parts yesterday for what was available I changed out the fuel pump actuator And the pressure relief valve on the fuel rail
part number 4307411nx actuator
part number 4307226 valve
Neither one changed anything is the problem I’m having is I start the truck it’ll run for 30 seconds or so normal smooth idle and then shut down tired of this it was running fine no issues whatsoever I just topped off my tank’s in Missoula about 100 miles back
Prior to changing those two parts I checked the voltage at the connector for the high-pressure fuel rail sensor like quickserv states in the troubleshooting manual and you got 5.1 V
I would’ve bought one of these as well but they did not have one
I checked the resistance across the actuator and got the 2.8 ohms
I remove the banjo bolts on the fuel pump and check the screen inside of it and it was clean absolutely no livery I change the fuel filter’s and they were free from any metal shavings
I remove the lift pump and checked inside of it and checked the connections a fuel lines to it for any kind of leaks found nothing
Only thing that I have found that is different gods and he is in the air bleeder on the house in fuel filter head where I would normally do you press to release air in the system when changing fuel filters ,running or priming up there seems to be normal pressure but as soon as the truck turns off there’s barely any and at the fuel rail and barely no time at all and there’s no pressure
There’s no one in the area who’s any knowledge or that plug into my truck due to the delete of that can help the truck was the Demandated at the beginning of the year and haven’t had any issues sense I don’t have insight or a computer I’m working everything I know to off of quick serve
Any possible experience or help given would be greatly appreciated my batteries are running low and the truck won’t run long enough to charge them I don’t have the 12 sided socket to remove the bolts in the head of the feel pump in due to driveline repairs recently I have depleted my maintenance fund and don’t have the money for hook I’m in a bad spot boys . Thank y’all
