I am installing a amsoil bypass filter and need a little assistance. Ware should I put the pressure and return lines on my ISX ?[/align]
(06-22-2019 )flatbed94kid Wrote: [ -> ]this is what i did:
https://youtu.be/73lOdfk5Hzs
Thanks for the vid. Good idea with the J-bolts.... looks like a good spot for the filter/housing for the Cascadia. Seems like it's gong to be super easy to change when it's time.
Ok update I think I got it I installed the filter behind the sleeper...no other place...I found a picture of the oil cooler with numbers on the ports I used #5 and my return is in a plug on the block on the oil pan flange to the rear of the filter
Here is a picture of the cooler I used #5 I hope this is ok
looks like the right one. some of the other ones can get the hoses burned from being close to turbo or something.
(06-23-2019 )flatbed94kid Wrote: [ -> ]looks like the right one. some of the other ones can get the hoses burned from being close to turbo or something.
Thanks I wasn't sure...now to get the fittings and get some heat wrap for the hose...thanks again
