There's some old threads but I'm wondering if anyone knows a source for the spring in the regulator. I'm tempted to try the dimes trick and here's my reason. I can run 5000ish miles before my oil pressure drops to 20 psi then turns the motor off. I've got no leaks, and I don't burn oil. 839510 miles. I've seen on another forum a guy going through the issue I have and he replaced his pump and it didn't help increase his oil pressure. The pumps are remanned and maybe not every pump gets a new spring so my thinking is try a new spring and maybe 8-10 dimes. Has anyone gone thru this and tried the dimes spacer trick? For that matter does anyone here offer a proper spacer so dimes don't need to be used? I'm still making payments on this truck and I can't keep doing oil changes every 5000 miles I'd really appreciate some insight and help.
I think it's dimes and something like 6 to 10 dimes
Oh jeez yeah I meant dimes. I fixed it.
That's not gonna help your oil pressure problem. Your problem is soot is building up in The oil and plugging the oil filter. So try to find the main problem. Check for over fueling injectors or check your compression/blow by. It might be a broken ring like mine. My 871 does the same thing and I just add some oil change the filter out at 7,000 miles. I've been running mine like this for over a year now lol.
(07-19-2019 )cawakening Wrote: [ -> ]There's some old threads but I'm wondering if anyone knows a source for the spring in the regulator. I'm tempted to try the dimes trick and here's my reason. I can run 5000ish miles before my oil pressure drops to 20 psi then turns the motor off. I've got no leaks, and I don't burn oil. 839510 miles. I've seen on another forum a guy going through the issue I have and he replaced his pump and it didn't help increase his oil pressure. The pumps are remanned and maybe not every pump gets a new spring so my thinking is try a new spring and maybe 8-10 dimes. Has anyone gone thru this and tried the dimes spacer trick? For that matter does anyone here offer a proper spacer so dimes don't need to be used? I'm still making payments on this truck and I can't keep doing oil changes every 5000 miles I'd really appreciate some insight and help.
your problem is not your oil pump -- IT IS A SEVERE SOOT PROBLEM --- FIX THE DAMN ENGINE1!!!!!!!!!!
http://rawze.com/forums/showthread.php?t...6#pid31116
That's why I posted here. To find more than one person post about the problem and see more than one person post about a resolution.
Yep, something is causing excessive soot to buildup. Fix that problem first then put some dimes or a stainless shim under the regulator spring
@rawze have you guys had anything like this happen from the oil pump shim?
800,000 + miles, time to replace the bearings in the lower end too...
