09-22-2019,
I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
tia
(09-22-2019 )Pd6cas2 Wrote: [ -> ]Hi
I don’t mean to change topic but if anyone suggest RoadKing shocks, There out of business!
I’m stuck with two $295 Anvils!
I was waiting to get them rebuilt, now I have To return to regular shocks.
(09-22-2019 )hhow55 Wrote: [ -> ]I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
(09-22-2019 )Rawze Wrote: [ -> ]What about it is hard to maintain? Just curious, ive seen a handfull of them on the used truck market.(09-22-2019 )hhow55 Wrote: [ -> ]I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
just stay away from hendrickson air front ends.. I have one and it rides real nice, but is a nightmare to maintain.
(09-22-2019 )smorgan87 Wrote: [ -> ]Rawze's truck has a very odd suspension setup even the front axle is completely different I think, think of a rear axle trailarm suspension in a souped-up muscle car opposed to a typical leaf spring suspension with airbags on it were all use to. Many more bushings that are prone to failure and very unstable handling at times.(09-22-2019 )Rawze Wrote: [ -> ]What about it is hard to maintain? Just curious, ive seen a handfull of them on the used truck market.(09-22-2019 )hhow55 Wrote: [ -> ]I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
(09-22-2019 )marek4792 Wrote: [ -> ]So the same as a solid front axle 4x4 pickup?(09-22-2019 )smorgan87 Wrote: [ -> ]Rawze's truck has a very odd suspension setup even the front axle is completely different I think, think of a rear axle trailarm suspension in a souped-up muscle car opposed to a typical leaf spring suspension with airbags on it were all use to. Many more bushings that are prone to failure and very unstable handling at times.(09-22-2019 )Rawze Wrote: [ -> ]What about it is hard to maintain? Just curious, ive seen a handfull of them on the used truck market.(09-22-2019 )hhow55 Wrote: [ -> ]I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
(09-22-2019 )smorgan87 Wrote: [ -> ]pretty much(09-22-2019 )marek4792 Wrote: [ -> ]So the same as a solid front axle 4x4 pickup?(09-22-2019 )smorgan87 Wrote: [ -> ]Rawze's truck has a very odd suspension setup even the front axle is completely different I think, think of a rear axle trailarm suspension in a souped-up muscle car opposed to a typical leaf spring suspension with airbags on it were all use to. Many more bushings that are prone to failure and very unstable handling at times.(09-22-2019 )Rawze Wrote: [ -> ]What about it is hard to maintain? Just curious, ive seen a handfull of them on the used truck market.(09-22-2019 )hhow55 Wrote: [ -> ]I have 2010 kw t660, and I am seeking advice on an add on air bag system for the steer axle. I'm primarily interested in reliability, and comfort.
tia
