Looking for a good code scanner I’m a o/o just want to check codes and clear them and do a Regen is need be thanks
So I would just need a pc and download the file and if would read/clear codes ? I’m new to this stuff
I was looking at the Cando hdcode2
I use this to just read the codes, it won’t clear them but if ya fix the underlying issue the fault code will go inactive or clear itself anyway.
(09-06-2020 )JAsaro Wrote: [ -> ]I was looking at the Cando hdcode2
Just get an old laptop wipe it clean and install insite. Then don't use it for anything but working on your engine, don't surf the interweb and hang out on pornhub with it.
If you have a cummins you NEED insite!! Not ANYTHING else. Just buy the inline adapter that waterloo linked for you and call it a day. It does all diagnostic tests, read/clear codes,forced regen's, dpf resets, computer reflashing, etc. Anything else you buy won't be as good and will probably cost a LOT more.
(09-06-2020 )tree98 Wrote: [ -> ] (09-06-2020 )JAsaro Wrote: [ -> ]I was looking at the Cando hdcode2
Sorry does it come with the insite installed or do I have to buy and download it myself
