Hello everyone I have 2007 Cummins isx15 Cm870 pulled valve cover off and noticed the tension on rocker 5,6 for jake brake felt weak when I pushed them down into the detent position and when at ideal it makes a rattling sound it has 800k on motor did over head on it still same sound does anyone know if you have to change rocker shaft or rockers as well for the jakes?
You need new rocker shafts. Also pays to change the detent pistons and springs at the same time. They come in a kit (2882081)
Thank you for the reply had another question for you I bought this truck with Egr deleted and wanted to know if there was way to find out if the program/tune was done right or if someone can take a look at it.
(02-01-2022 )Beast15 Wrote: [ -> ]Thank you for the reply had another question for you I bought this truck with Egr deleted and wanted to know if there was way to find out if the program/tune was done right or if someone can take a look at it.
copy the program out of the ecm and e-mail it to me for a review.
ref:
http://rawze.com/forums/showthread.php?t...2#pid68742
For anybody know if the rocker bearings are wore out do you have to replace whole rocker or can the bearing be replaced
I'm sure you can buy the bushes but I've never looked to see how available they are. They usually show some wear but will last a very long time.
If you mean the rollers or their brass shafts, replace the whole rocker.
(02-01-2022 )Rawze Wrote: [ -> ] (02-01-2022 )Beast15 Wrote: [ -> ]Thank you for the reply had another question for you I bought this truck with Egr deleted and wanted to know if there was way to find out if the program/tune was done right or if someone can take a look at it.
ref: http://rawze.com/forums/showthread.php?t...2#pid68742
Hi Rawz I never used Calter and don’t even know where to start do you know anybody here that can connect remotely to my computer to see if the program that is in it any good the Egr has been deleted and the Egts run kinda high under heavy load it goes up to 1k any help would be appreciated.
Thank you
(02-21-2022 )Beast15 Wrote: [ -> ] (02-01-2022 )Rawze Wrote: [ -> ] (02-01-2022 )Beast15 Wrote: [ -> ]Thank you for the reply had another question for you I bought this truck with Egr deleted and wanted to know if there was way to find out if the program/tune was done right or if someone can take a look at it.
Thank you
maybe this post helps..
ref:
http://rawze.com/forums/showthread.php?t...0#pid70300
With 1 mil on the jake rockers would be a wise investment to replace rocker shaft along with jake rockers. THe plungers over time get alot of ware in the barrel part of jake rocker and the get weak and will bypass oil thus causing weak jake or some say a vibration during jaking.
