11-20-2023,
Hi all
Have an aussie ISX15 E5 in one of my trucks. Doesnt do any on road work. Off road work only so is not subjected to running mandated emissions.
I will post all info below on ECM/Engine.
Had a delete years ago, then someone turned the adblu/SCR back on so cummins could do a rebuild on the engine, problem is they never cleaned the SCR Canister and it became so blocked it cause massive turbo back pressure issues. I have since gutted the SCR canister, but now obviously i am getting alot of Nox error codes and derates.
How do i go about deleting these, i do not need the SCR to be functional, hence why i gutted the SCR canister. As the Nox and SCR unit is seperate to the truck engines, can i just put block codes in with calterm on the 2 codes causing me derates? or what other options people suggest. Seen plenty of delete files out there for the ISX15-e5 but they are for engines with EGR, DPF and SCR. We dont run them here in Australia. Ours only have SCR (Adblu/Def)
This ECM has a factory 600hp/2050ft tune in it. Which is needs to retain as its a 170ton (370,000lbs) rated truck, pulling quad trailers in a mine.
esn 79711168
p/n 4993120
s/n 28786
d/c 01092014
e/c ds10005.05-800
Marketing Engine Configuration #
D103011BB05
Marketing Model Name
ISX15E5 550
Service Model Name
ISX15 CM2250 SN
Technical Engine Configuration #
D103011BX03
ENGINE BUILD DETAILS
Build Date
2014-01-08T00:00:00Z
Build Plant
JEP - JAMESTOWN ENGINE PLANT
CPL #
3574
Shop Order
SO39597
Warranty Start Date
2015-09-03T00:00:00Z
TECHNICAL SPECIFICATION DETAILS
ECM Code
DS10005
Fuel Pump Part #
4307527
Fuel Pump Calibration
PE21[/font]
esn 79711168
p/n 4993120
s/n 28786
d/c 01092014
e/c ds10005.05-800
D103011BB05
ISX15E5 550
Service Model Name
ISX15 CM2250 SN
D103011BX03
Build Date
Build Plant
CPL #
3574
Shop Order
SO39597
Warranty Start Date
ECM Code
DS10005
Fuel Pump Part #
4307527
PE21[/font]
