Full Version: Isx cm871 front gear housing dowty washers
Front Gear housing captive bolts sealing washers
Hello Rawze nation , I have a question about the dowty
Sealing washers on the front gear housing. Are the sealing
Washers on the bolts reusable?.
Thank you in advance.
Might be best to replace them if you don't plan on taking it apart for the next million miles.
Whenever I do re-use one though, I spray a wax coating on hem to help their longevity...
ref: https://amzn.to/3Vgt9KO
(03-12-2024 )Rawze Wrote: [ -> ]Might be best to replace them if you don't plan on taking it apart for the next million miles.
They are m10 bolts would it a be problem to use 3/8 seal washers ?
Cummins don’t offer the washers they only offer the bolts with the
Washers as a unit at $10 a screw . I’m thinking after market
Sealing washers. Can’t seem to find m10 dowty washers.
Reference URL's
