|  Isx cm871 front gear housing dowty washers  |
|  03-12-2024, (Subject: Isx cm871 front gear housing dowty washers )  Post: #1 | |||
| Isx cm871 front gear housing dowty washers  Front Gear housing captive bolts sealing washers Hello Rawze nation , I have a question about the dowty Sealing washers on the front gear housing. Are the sealing Washers on the bolts reusable?. Thank you in advance. | |||
|  03-12-2024, (Subject: Isx cm871 front gear housing dowty washers )  Post: #2 | |||
| RE: Isx cm871 front gear housing dowty washers  Might be best to replace them if you don't plan on taking it apart for the next million miles. Whenever I do re-use one though, I spray a wax coating on hem to help their longevity... ref: https://amzn.to/3Vgt9KO User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  03-12-2024, (Subject: Isx cm871 front gear housing dowty washers )  Post: #3 | |||
| RE: Isx cm871 front gear housing dowty washers (03-12-2024 )Rawze Wrote: Might be best to replace them if you don't plan on taking it apart for the next million miles. They are m10 bolts would it a be problem to use 3/8 seal washers ? Cummins don’t offer the washers they only offer the bolts with the Washers as a unit at $10 a screw . I’m thinking after market Sealing washers. Can’t seem to find m10 dowty washers. | |||
