| Ecm issue |
| 10-27-2025, (Subject: Ecm issue ) Post: #10 | |||
| RE: Ecm issue I've got everything off other engine so thats no problem just the custom program is i guess. I dont care one way or the other about de-mandating one way or the other. I was going to not but I didn't know that was not an option. | |||
| Today, (Subject: Ecm issue ) Post: #11 | |||
RE: Ecm issue (10-27-2025 )JTX Wrote: I've got everything off other engine so thats no problem just the custom program is i guess. I dont care one way or the other about de-mandating one way or the other. I was going to not but I didn't know that was not an option. So the question now is ... does it have the older ECM and older engine wiring harness on it?... or did you use the newer ECM and newer wiring harness?. - You still have not specified this. And/or have you installed the older ecm and harness, now that you know better? ... and if you want to have a program made for it, then you need to get the engine running, codes cleared and resolved, etc ... (with the older harness and ecm), and then copy the program out of the ecm and e-mail it to me so that I can put all the proper data in it such as compression ratio, injector programming and compensations, fuel-air-mix, cam profile offsets, and all the other stuffs that belong to that different model engine. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
