Reprogram issue :/ |
02-05-2020, (Subject: Reprogram issue :/ ) Post: #10 | |||
RE: Reprogram issue :/ (01-30-2020 )Rawze Wrote: First thing I always do when someone comes over here is make a pdf document printout of the entire 'Features and parameters' settings that are showing in insite before making any kind of changes. Seen this happen too many times. I tried to do this, where can i find instructions on the procedure i have a file i would like you to look at. Thanks | |||
02-05-2020, (Subject: Reprogram issue :/ ) Post: #11 | |||
RE: Reprogram issue :/ (02-05-2020 )2dlb Wrote:(01-30-2020 )Rawze Wrote: First thing I always do when someone comes over here is make a pdf document printout of the entire 'Features and parameters' settings that are showing in insite before making any kind of changes. Seen this happen too many times. just open up the 'features and parameters' section in insite, expand all, then print it out. I think doing a complete ecm report, it is included as well. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-05-2020, (Subject: Reprogram issue :/ ) Post: #12 | |||
RE: Reprogram issue :/ In modern windows I have win 10 today you can "print to PDF" instead of an actual printer. And it will create a PDF of what you would have printed User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
