| Isx Cm871 Injector leak test |
| 11-03-2024, (Subject: Isx Cm871 Injector leak test ) Post: #10 | |||
RE: Isx Cm871 Injector leak test (11-02-2024 )CM87183 Wrote: ... - I have had that happen a few times. Only thing you can do is crank the engine for a good 20+ seconds to get it leaking/bubbling real good, then jump out quickly and bar the engine right away .. and it will continue to leak. Its like you have to get it going/leaking good, then jump out and turn engine by hand right away after, like your trying to catch it before it goes away again. - You can use 2 people to do this (someone to shove the wrench in right away after a good bit of cranking it, and start turning engine by hand) .. but you have to have enough trust in them not to leave/have the wrench in place when you use the starter to crank it/vice versa. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
