Paccar fuel filter doesn't stay full |
02-28-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #19 | |||
RE: Paccar fuel filter doesn't stay full Thanks Rawze. This just started after air in fuel-water separator episode. I changed to the 30 micron filter to keep fuel pump from cavitating or killing injectors with air trapped in fuel system. The so-called new and improved fuel pump was priced to me for $4960 from Peterbilt. Wanted to make sure I needed it before I spent that kind of money. I'm new to this forum so be patient with me as I learn. | |||
02-28-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #20 | |||
RE: Paccar fuel filter doesn't stay full I think my reply and question got passed over because this guy posted in my thread. On the fuel line on the passenger side tank there's dirty looking fuel. I had a mechanic tell me that wouldn't cause a problem. I tried tightening the fitting. Do you think that's causing the problem? Should I replace that hose? Thanks. | |||
02-28-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #21 | |||
RE: Paccar fuel filter doesn't stay full (02-28-2018 )aaronb Wrote: I think my reply and question got passed over because this guy posted in my thread. On the fuel line on the passenger side tank there's dirty looking fuel. I had a mechanic tell me that wouldn't cause a problem. I tried tightening the fitting. Do you think that's causing the problem? Should I replace that hose? Thanks. Any fuel leak in a fuel line is a problem that should be fixed right away. Maybe post some pictures? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-28-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #22 | |||
RE: Paccar fuel filter doesn't stay full Here's a few pictures. I just sprayed it with carburetor cleaner to try and clean it up some so I can try and see where the leak is. | |||
03-02-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #23 | |||
RE: Paccar fuel filter doesn't stay full There is a small hole on top of the filter next to the rubber seal that gets clogged up. I'm thinking it's there to equalize fuel inside and outside of filter element. I noticed when I changed my filter one time it had a big glob of crap around that rubber seal. When this happens inside of filter stays full of fuel and creates the air pocket around the outside. If that little hole wasn't sunken down in the top like that it probably wouldn't happen as often as it does because any trash will settle to the bottom of everything. Hope this helps everyone with the Paccar setup. Next time this happens check that tiny hole on top. | |||
03-02-2018, (Subject: Paccar fuel filter doesn't stay full ) Post: #24 | |||
RE: Paccar fuel filter doesn't stay full Fuel return line should be air tight and always under fuel. If it's not fuel will flow back when engine not running. Don't know for sure for 871 but 2250 2350. ![]() | |||
02-02-2025, (Subject: Paccar fuel filter doesn't stay full ) Post: #25 | |||
RE: Paccar fuel filter doesn't stay full (02-28-2018 )aaronb Wrote: Here's a few pictures. I just sprayed it with carburetor cleaner to try and clean it up some so I can try and see where the leak is. Hi this is Ozzy. I just sent you a private message. Any info on what the solution was for you?? This seem to be your last message on the topic. Im having the same issue. Any information is highly appreciated. Thanks | |||
02-03-2025, (Subject: Paccar fuel filter doesn't stay full ) Post: #26 | |||
RE: Paccar fuel filter doesn't stay full (02-02-2025 )Ozzypete388 Wrote:(02-28-2018 )aaronb Wrote: Here's a few pictures. I just sprayed it with carburetor cleaner to try and clean it up some so I can try and see where the leak is. == That style of fuel water separator (with the hanging style glass bowl) is notorious for leaking/sucking air at the gasket at the top where the bowl screws on. == The check valve at the inlet line connection can go bad or get trash in it. == Fuel lines sucking air can do it. (in which case, this post can help find it... : https://rawze.com/forums/showthread.php?...9#pid24029 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
