Cm2350 overhaul questions |
09-10-2021, (Subject: Cm2350 overhaul questions ) Post: #19 | |||
RE: Cm2350 overhaul questions (09-10-2021 )Smiling lemon Wrote:(09-10-2021 )Rawze Wrote: I guess some people just want to tear their equipment up by running the wrong coolant.. or only water?... then if the coolant is a pretty bright red and tests ok... and that rusty liquid is what came out of the filter ... the answer will be... that the damn coolant shut-off valve was not in the open position ... and that filter sat in a dead space for a very long time, not doing anything. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
09-10-2021, (Subject: Cm2350 overhaul questions ) Post: #20 | |||
RE: Cm2350 overhaul questions It is possible but more likely when I flushed the cooling system it rusted some and filter grabbed a lot of gunk from that and it had also been on there awhile. It is off of my apu lines and I was going to change it as oil change time maintenance for it but it has not reached that time limit and it started leaking. | |||
