ISX and Bypass Oil Filter Systems |
08-01-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #55 | |||
RE: ISX and Bypass Oil Filter Systems i have the same kit, if i remember it's a AN6 fitting that will work. or jic(same thing) fittings that came with it. just take 1 of the fittings to a hose or farm(ih case JD) dealer they should have what you need.just read through the post its in here somewhere.:) | |||
08-01-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #56 | |||
RE: ISX and Bypass Oil Filter Systems Not the jic size, the other end that threads into the base. I'm looking to order it online. I don't have the kit yet. I think it might be 3/8? | |||
08-01-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #57 | |||
RE: ISX and Bypass Oil Filter Systems Nevermind found it. It's 3/8 x 1/2 jic | |||
08-10-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #58 | |||
RE: ISX and Bypass Oil Filter Systems Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance. | |||
08-11-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #59 | |||
RE: ISX and Bypass Oil Filter Systems (08-10-2016 )Inderjit Wrote: Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance. 9068-08-18 9068-08-18 | 1/2" JIC Male x M18x1.5 Metric Male w/ seal $6.24 $5.87 9068-08-14 9068-08-14 | 1/2" JIC Male x M14x1.5 Metric Male w/ seal $7.05 $6.63 http://www.discounthydraulichose.com/906...p/9068.htm This is a link to order the fittings online. Cuz fitting may be hard to find in some stores | |||
08-11-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #60 | |||
RE: ISX and Bypass Oil Filter Systems (08-11-2016 )jimeneztrans84 Wrote:(08-10-2016 )Inderjit Wrote: Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance. Thanks so much for part numbers. Little more help if you have part number for 90 deg elbow fittings for amsoil filter housing. Thanks again. | |||
08-11-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #61 | |||
RE: ISX and Bypass Oil Filter Systems 2501-08-06 | 1/2" JIC Male x 3/8" NPTF Male Pipe 90° On the fittings for the engine feed and return make sure you leave the o ring only, take off the washer it comes with. | |||
08-14-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #62 | |||
RE: ISX and Bypass Oil Filter Systems Thank you sir | |||
08-17-2016, (Subject: ISX and Bypass Oil Filter Systems ) Post: #63 | |||
RE: ISX and Bypass Oil Filter Systems (04-03-2016 )Rawze Wrote:Hey Rawze can I get part number the for the fitting at the inlet port of filter housing? Not the elbow but the other with a bend on it.(04-03-2016 )Waterloo Wrote: For the bypass oil filter, where did you guys put the return line? Back to the oil pan I am assuming? Now, did you drill a hole in the pan or use the drain plug on the passenger side of the motor? Or is there someplace else to attach the oil return line? My motor is in a thousand pieces right now, and I am thinking this would be a good time to install a by pass filter, or at least get the plumbing started. | |||
