Series 60 Trip report view
12-08-2016, (Subject: Series 60 Trip report view )
Here is my old truck report.
./uploads/201612/post_2435_1481189249_f783ac1675662b53999a2f08f8b0351f.jpg./uploads/201612/post_2435_1481189295_6d7c9740fb70eec8b1a8ba44cfd57fae.jpg./uploads/201612/post_2435_1481189335_890275ea93c0a832bb69c9224af9a4ef.jpg./uploads/201612/post_2435_1481189383_af14b9cf161e06e9805301df8ff63370.jpg
RE: Series 60 Trip report view
Better pic.
./uploads/201612/post_2435_1481189632_a141776f24cf55d1ff704107d5fe9015.jpg
(12-08-2016 )Jarhead79 Wrote:  Better pic.
It shows you idle waaay too much, and drive waaay too fast!
I started to purchase the truck at 800,000 miles. But I did drive fast. And no apu.
12-09-2016, (Subject: Series 60 Trip report view )
103 mph WOW
12-10-2016, (Subject: Series 60 Trip report view )
This was the first trip report ever for that truck at 1million miles.
2903rpm....is your motor still running? should be in pieces at that rpm...
User's Signature: You want how much?
(12-10-2016 )scottydogtruck Wrote:  2903rpm....is your motor still running? should be in pieces at that rpm...
Still ran like a clock. I blew the fan clutch at rpm when the fan was ingauged.
12-11-2016, (Subject: Series 60 Trip report view )
Detroits will handle a lot of rpm. The entire reciprocating assembly is very light weight and the stroke is relatively short. My friend Herb is a S60 loon and has a hot rodded Detroit and pulls hills at 32-3300rpm. Some place in CA did the ecm with mapping to 3600rpm. It won't be far behind my Cat up a mountain but will be turning more than twice the rpm. His is not a reliable setup, hydro locked once and had a runaway turbo on the 301 in FL. Been torn apart 3 times in last two years.
