Error 5081
01-23-2017, (Subject: Error 5081 )
Error 5081
Just purchased an 06 Volvo with a CM870. Trying to remove the 62 MPH road speed governor with Insite. Insite tells me the ECM has an invalid Footprint and must be recalibrated. Also says it was caused by a previous operation that left the ECM in an Invalid State.
This is the first time I've hooked up to this truck - used to be a "fleet" truck I believe.
Any thoughts? Or can anyone recalibrate this ECM?
Thanks
RE: Error 5081
(01-23-2017 )Vulcantweet Wrote:  Just purchased an 06 Volvo with a CM870. Trying to remove the 62 MPH road speed governor with Insite. Insite tells me the ECM has an invalid Footprint and must be recalibrated. Also says it was caused by a previous operation that left the ECM in an Invalid State.
Thanks
Unilevers and/or gearhead are both very good with CM870.
