bypass hook up |
04-02-2016, (Subject: bypass hook up ) Post: #1 | |||
![]() Well most that have hooked up a bypass oil filter. never really tell how they have hooked it up or what fittings they had to get, and if they used a shut off valve(1 end or both) so i thought id ask to find out...and ask.. How did you hook up your bypass filter, like what fittings did you need,type did you get?(amsoil,2500.G/C.) and how did you do the lines. like return to the oil pan or some other location. as some may have a better placement for the return than the oil pan. ( i think it's to low. ie: big chunks of snow, WY.go figure :s) Thanks in advance. | |||
04-02-2016, (Subject: bypass hook up ) Post: #2 | |||
RE: bypass hook up | |||
04-03-2016, (Subject: bypass hook up ) Post: #3 | |||
RE: bypass hook up User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
04-07-2016, (Subject: bypass hook up ) Post: #4 | |||
RE: bypass hook up i did read it, but you guys add more to it after i did... sorry i'm slow sometimes :) | |||
