04-02-2016,
Well most that have hooked up a bypass oil filter. never really tell how they have hooked it up or what fittings they had to get, and if they used a shut off valve(1 end or both) so i thought id ask to find out...and ask..
How did you hook up your bypass filter, like what fittings did you need,type did you get?(amsoil,2500.G/C.) and how did you do the lines. like return to the oil pan or some other location. as some may have a better placement for the return than the oil pan. ( i think it's to low. ie: big chunks of snow, WY.go figure :s)
Thanks in advance.
Thanks in advance.
