Rawze's Daily blog...
05-09-2016, (Subject: Rawze's Daily blog... )
Post: #28
RE: Rawze's Daily blog...
http://www.prelub.com/web/Engine-Pre-Lube/index.html
05-10-2016, (Subject: Rawze's Daily blog... )
Post: #29
(05-09-2016 )hhow55 Wrote:  http://www.prelub.com/web/Engine-Pre-Lube/index.html
It really bugs me that they can't put a price on their product without contacting them.
Quote:
It Doesn't Cost-It Pays. A Cummins Prelub™ starter can save your customer thousands of dollars in engine overhaul costs. Pay-back period for the initial investment can be as low as six months. And if the Prelub™ system saves just one turbo over the life of the engine overhaul, it has virtually paid for itself.
So in other words, it costs as much as a turbo. I'd really like to know how they figure the payback, as low as 6 months? Sounds like they're figuring how much they can get out of my wallet. Should be standard equipment but then they wouldn't sell all the saved parts.
Post: #30
I think before I spent the money on that I would just wire up a switch to oil pressure sending unit so truck wouldn't start till it had oil pressure. Cost would only be 20 to 30 dollars and a little time.After thinking about it there maybe a parameter in ECM to keep engine from starting till you have oil pressure
Post: #31
Cummins had problems with their version of a prelub starter a few years ago. I know the guys restoring military Cummins engines in military vehicles were buying them and destroying the parts when the preluber failed.
Hopefully Cummins has improved those.
05-11-2016, (Subject: Rawze's Daily blog... )
Post: #32
Flushing water out today and filling it with red coolant. Also going to take it to speedco and have the oil/filters changed that was used for the initial startup.
Here is rough breakdown of what i have spent...
This is what I have in it roughly ...
$3830 -- Overhaul Kit (I purchased this a while back, so I did not spend it this go around).
$3560 -- Head (Brand new, not reman).
$1695 -- 3 reman injectors ($565 ea.)
$1050 -- New Alternator (320 Amps, Not reman)
$470 -- New Oil Pump (shimmed the regulator with 10 dimes as well and it makes 48-50 PSI).
$304 -- Rod Bearings
$184 -- Main bearings
$180 -- Lower Radiator frame bracket (old one was rusted out).
$150 -- Oil pan gasket
$58 -- Exhaust manifold bolts
$??? -- O-ring for top of thermostat
$??? -- New Main Supply Hose for Radiator
$??? -- Some 3/8" Air line.
$??? -- A/C Belt tensioner
$??? -- Main Belt Tensioner
$??? -- New Belts
$??? -- New Coolant (Red)
$??? -- Oil used for startup ($7.50 / gal El-cheapo oil + 1 gallon of 80/90 gear lube)
$??? -- Oil change at Speedco after test driving it.
$???? -- 4 cans of R134a to re-charge the A/C with.
It comes in at right around 12k or so. I did the job myself, including counter-boring my own block so there is no labor bill.
YES, this is/was a low-rent type of project. I see no point in replacing a bunch of extra stuff and running up the bill all at once. I will get it back on the road and slowly replace things as needed from here. I didn't even bother to re-paint anything or even pull/replace the oil cooler, etc. -- I just wanted to do the minimum job, but I did do it right.
 Thanks given by: 386lover , gatow900 , LargeCar
Post: #33
What kind of special tools was needed?
Post: #34
(05-11-2016 )Rawze Wrote:  Flushing water out today and filling it with red coolant. Also going to take it to speedco and have the oil/filters changed that was used for the initial startup.
$470 -- New Oil Pump (shimmed it with 10 dimnes as well and it makes 48-50 PSI).
$??? -- New Belts
Damb! I did a reman oilpumps & didn't shim it
Post: #35
Seeing as it's so easy to raise the oil pressure in an ISX is there some logical reason Cummins set it so low? My Volvo D13 with 15/40 Rotella runs 60 - 65 psi at road speed.
05-12-2016, (Subject: Rawze's Daily blog... )
Post: #36
(05-11-2016 )kryten Wrote:  Seeing as it's so easy to raise the oil pressure in an ISX is there some logical reason Cummins set it so low? My Volvo D13 with 15/40 Rotella runs 60 - 65 psi at road speed.
Some background info has revealed that they lowered the pressure because the extra pressure was washing out rod and main bearings on older models. I would suspect that they possibly carried that through to the newer engines.
I had a million miles on mine, and everything looked like new except the valve stems and overhead cam bearings. This was with the default 34-40 psi,.. so I see no potential in the stock pressure being a problem at all. I increased it to 48-50-psi just out of sheer curiosity, so perhaps it will extend the life of the head? -- not sure it will help, only time will tell.
