Engine Brake Light
03-08-2019, (Subject: Engine Brake Light )
Engine Brake Light
Does anyone know a possible part number for the 4 bulbs for Engine Brake/Luggage Door/Regen/Hot Exhaust lights in the dash module?
International supposidly could only find the whole new module for $60 bucks but its just a burnt out light as i swapped a Regen light into my Engine Brake section since it was burned out and now i get ESC Warning because it sees the Regen light is now the burnt out one.
At least my engine brake "on" light works now lol.
RE: Engine Brake Light
Picture of the old bulb? Is it long skinny type with a flat base that has exposed wires?
i cant find a pic on google but its real small say 3-4mm round bulb with a flat round base you push through the circuit board then twist 30-45 degree to lock in. maybe 1/2in tall
its the lights in your 4 light section on the dash of prostars/lonestars
Maybe a #1893 bulb?
They are like this style but much smaller then what you would put in your gauges at first i thought it was LED until i saw the filiments inside it thats how small the bulb is kinda like the pick of an LED. Ill pull dash back apart tomorrow get a real pick of one i just really dont wanna pay 60 bucks when my module is good just the damn push through twist 30degree light isnt.
./uploads/201903/post_3856_1552101698_045ccf0c34ab1601d91d8bc1421a7f12.jpg./uploads/201903/post_3856_1552101706_1c9bd723d6a3905e034a408650e4b912.jpg
03-09-2019, (Subject: Engine Brake Light )
Freightliner century class used to use a very small bulb in the dash switches. Very few people knew they were replaceable. A small piece of plastic tubing slid over the bulb and you could pull them straight out of the switch. Literally a $.05 fix compared to a $30 switch. So ya, a picture of the actual bulb with something for reference in size next to it would help a lot.
Pull a burnt old bulb and bring it in to intersmashable or Napa .
