|  Isx cm2250 deleted have code SPN3058 Fmi 18  |
|  05-07-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #1 | |||
| Isx cm2250 deleted have code SPN3058 Fmi 18  Hi I have Cummins ISX CM2250 with code SA 0 SPN 3058 FMI 18 truck it’s been deleted and already replaced Delta pressure sensor  | |||
|  05-07-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #2 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18  Google says...  Blockage, restrictions, or leaks in the EGR differential pressure sensor ports Leaking EGR valve Stuck open EGR valve Malfunctioning EGR differential pressure sesnor. Maybe an EGR Tuneup is warranted? | |||
|  05-07-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #3 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18 (05-07-2019 )svraka Wrote: Hi I have Cummins ISX CM2250 with code SA 0 SPN 3058 FMI 18 truck it’s been deleted and already replaced Delta pressure sensor who did the de-mandate? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  05-10-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #4 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18  Rawze that’s good question?As I know somebody from Davenport,IA  | |||
|  05-11-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #5 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18  if it was demanded correctly there would be no EGR Dif alarms if im not mistaken. sounds like another truck that needs its program pulled/inspected and probably corrected by the real pros unless for some reason someone would leave the egr system on and only remove dpf.  | |||
|  05-11-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #6 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18 | |||
|  05-11-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #7 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18 (05-10-2019 )svraka Wrote: Rawze that’s good question?As I know somebody from Davenport,IA get the program copied out of the ecm and e-mail it to me for an inspection. that would be my first recommendation. Until you can verify the integrity of the programming, your pissing in the wind and potentially driving an engine hell bent on destroying itself. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  05-14-2019, (Subject: Isx cm2250 deleted have code SPN3058 Fmi 18 )  Post: #8 | |||
| RE: Isx cm2250 deleted have code SPN3058 Fmi 18 (05-11-2019 )Rawze Wrote:(05-10-2019 )svraka Wrote: Rawze that’s good question?As I know somebody from Davenport,IA Ok I will do that | |||
