| 2250 codes after demandate |
| 07-12-2019, (Subject: 2250 codes after demandate ) Post: #1 | |||
| 2250 codes after demandate 2014 Cascadia ISX Had a truck demanded yesterday. Test drive yesterday went well. This morning after about 30 min of running check engine lights came on, code 1894 VGT actuator driver circuit abnormal rate. Is it possible the programming isn't quite right or should I get this thing towed home and start VGT testing? | |||
| 07-12-2019, (Subject: 2250 codes after demandate ) Post: #2 | |||
| RE: 2250 codes after demandate If you had the truck demandated on the road at some random shop not approved here then truck is most likely screwed User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 07-12-2019, (Subject: 2250 codes after demandate ) Post: #3 | |||
| RE: 2250 codes after demandate If it was one of the officially recommended people on this forum, then you should get with them and find out what is going on. If not,.. then faults or not ... 99% likeliness you have just given your money away in exchange for a bad delete program that will eventually tear up your engine with a slow agonizing death. In this case,.. have the program copied out of the ecm and e-mail it to myself or one of the guys recommended on here to have it inspected so that you don't end up with an inframe due to dropped liner, or repeating turbo failures, or perhaps a piston through the side of the block in the near future. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-30-2019, (Subject: 2250 codes after demandate ) Post: #4 | |||
RE: 2250 codes after demandate (07-12-2019 )Rawze Wrote: If it was one of the officially recommended people on this forum, then you should get with them and find out what is going on. I don't mean to just jump in here, but we have a truck with a similar problem. It has also been demandated, but it is not performing like some of our other demandated trucks. I was wondering how do you copy the program out of the ecm to be reviewed? We just recently acquired calterms and was not sure if I could do it with that. | |||
| 07-30-2019, (Subject: 2250 codes after demandate ) Post: #5 | |||
| RE: 2250 codes after demandate My issue turned out to be faulty actuator. | |||
| 07-30-2019, (Subject: 2250 codes after demandate ) Post: #6 | |||
RE: 2250 codes after demandate (07-30-2019 )mhornac88 Wrote: I don't mean to just jump in here, but we have a truck with a similar problem. It has also been demandated, but it is not performing like some of our other demandated trucks. I was wondering how do you copy the program out of the ecm to be reviewed? We just recently acquired calterms and was not sure if I could do it with that. assuming is legal in your country. How to make backup of ECU to PC.pdf (Size: 1.69 MB / Downloads: 946){link removed} User's Signature: my wisdom is small. my heart is big. my love for trucking is somewhere in between. | |||
| 07-30-2019, (Subject: 2250 codes after demandate ) Post: #7 | |||
| RE: 2250 codes after demandate Prop, you've been a member here since oct. of last year. In all that time you haven't read all the posts on here from guys getting horrible programming in there trucks and ending up with problems? It makes me wonder how someone can find this forum and yet still end up with a bad demandate. I guess you can lead a horse to water........ | |||
| 07-31-2019, (Subject: 2250 codes after demandate ) Post: #8 | |||
RE: 2250 codes after demandate (07-30-2019 )MageRoyal Wrote:According to your post I need meta files in order to make this work. Where do I get those? Like I mentioned we are strictly trying to upload the ECM data to see how this certain truck matches with another one in the fleet. One truck has been having poor fuel economy and a lot of mechanical issues since it was altered.(07-30-2019 )mhornac88 Wrote: I don't mean to just jump in here, but we have a truck with a similar problem. It has also been demandated, but it is not performing like some of our other demandated trucks. I was wondering how do you copy the program out of the ecm to be reviewed? We just recently acquired calterms and was not sure if I could do it with that. | |||
| 07-31-2019, (Subject: 2250 codes after demandate ) Post: #9 | |||
| RE: 2250 codes after demandate filesharing is not allowed on this site. Those types of files are all over the internet for free on the dark www if a person just looks for them. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
