| DPF / ISX Problem TrUCK #2 |
| 09-23-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #1 | |||
| DPF / ISX Problem TrUCK #2 2015 Prostar 500 ISX - Engine Light came on with a Derate - DPF moderate severe level Etc Pulled off sent to International Cleaned / Baked - All the codes clear except the Ash Level? When I installed the freshly Baked DPF/Doc I did tell the ECM was cleaned thru insite. Did a forced Regen no change, Dealership told me to run it a round and let it go thru a couple Regens. NO Change Is there a seperate Ash Counter in Cummins Insite? If so i have not found. Is My Filter Done? | |||
| 09-23-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #2 | |||
| RE: DPF / ISX Problem TrUCK #2 you say you had it cleaned and baked... did they flow-test it? What does the regen history look like? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-24-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #3 | |||
| 09-24-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #4 | |||
| RE: DPF / ISX Problem TrUCK #2 | |||
| 09-24-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #5 | |||
| RE: DPF / ISX Problem TrUCK #2 Clean on Sept 16 I will have to call about the Flow Test , the ticket has Doc and DPF passed Green Tag? No Idea what that means, new to the DPF and learning | |||
| 09-24-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #6 | |||
| RE: DPF / ISX Problem TrUCK #2 If they are more then 250k miles old... Replace the DPF Delta-P sensor with a new one. Clean out the cross connecting pipes for it and ensure they are not leaky. NOTE: This next step should ONLY EVER BE DONE if you have just baked, flow-tested, etc, the DPF, (or replaced it with new one) ... -- Then perform a "Aftertreatment New filter Replacement" procedure in Insite. Doing a reset for new filter with an old dpf that is not flowing like a 100% brand new one will cause a lot of problems and false assumptions by the ecm. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-24-2019, (Subject: DPF / ISX Problem TrUCK #2 ) Post: #7 | |||
| RE: DPF / ISX Problem TrUCK #2 Yes Sir has 460K on truck Thank you, I will do as you suggested along with EGR Tune-up and update post accordingly, Thank you for the help | |||
