Tensioners and idler pulley
05-10-2021, (Subject: Tensioners and idler pulley )
./uploads/202105/post_1778_1620660099_b7a68101a248bd1412c1beeef84b20e1.jpeg   ./uploads/202105/post_1778_1620660158_6cf771bb0f2a6db17eff3384f37446a1.jpegThis may be repeat info. Bought new tensioners and pulley from Rock Auto. Much better price than dealer for basically the same thing. You might do better if you look around. Mine is a 2010 CM871 in a Peterbilt.
See this post in regards to the idler pulley. I’ve since bought a Cummins one instead.
http://rawze.com/forums/showthread.php?tid=7683
 Thanks given by: SquareOne , smorgan87 , stevesparts , Rawze , Volvo8873 , Waterloo , amermextrucker , barf , JMBT , wellrun
RE: Tensioners and idler pulley
Thanks for this.... been looking for an alternative as well. Cummins seems out of control for the price they want, Although, they have given me good service
 Thanks given by: Mrkentee
Thanks. Those cummins prices are insane even with a good discount at the parts house.
Thanks!! my a/c one was starting to make noise. great find. :)
User's Signature: hard to go 60 mph when the winds blowing 65+ in WY
05-11-2021, (Subject: Tensioners and idler pulley )
Gater, continental and Goodyear also are brand names to look in to. They make belts and tensioners that are OE equivalent and I've used since Ive owned a Cummins of any model. They hold up just as long as OEM and are 1/3 the price of anything direct from cummins. Often cummins slaps a cummins sticker over top of continental, Dayton and Goodyear parts.
 Thanks given by: smorgan87 , amermextrucker , Mrkentee
09-28-2021, (Subject: Tensioners and idler pulley )
Mrkentee, hows the alternative Dayco pulleys and tensioners been holding up for ya these last 4 months? Not much time to get a real review, but just curious if they've had any issue since install. About to order and replace mine shortly.
 Thanks given by: Rawze , Mrkentee
I just payed 275 for the tensioner on the main belt.
My 'cummins' from their warehouse says dayco right on it.
 Thanks given by: SquareOne , Chamberpains , Mrkentee
09-29-2021, (Subject: Tensioners and idler pulley )
(09-28-2021 )Pigpen 2869 Wrote:  I just payed 275 for the tensioner on the main belt.
Too bad you didn't see this post before purchasing it. There is a mountain of info like this scattered across the site.
