Component 138
09-20-2021, (Subject: Component 138 )
Component 138
What is component #138 spn520660. 2020 567 x15. Symptoms is intermittent abs, traction control and esp lights stay illuminated...
RE: Component 138
Its an OEM code, what make of truck is this?
RE: Component 138
(09-20-2021 )tree98 Wrote:  Its an OEM code, what make of truck is this?
Peterbilt 567
RE: Component 138
When is the last time you re-torqued all the hub bearings and put them back into spec? .. it is suposed to be done every 250k miles... The most common cause of ABS alarms and/or blown wheel seals are due to neglect of re-torquing all the hub bearings at regular intervals.
 Thanks given by: barf
09-21-2021, (Subject: Component 138 )
RE: Component 138
(09-20-2021 )Rawze Wrote:  When is the last time you re-torqued all the hub bearings and put them back into spec? .. it is suposed to be done every 250k miles... The most common cause of ABS alarms and/or blown wheel seals are due to neglect of re-torquing all the hub bearings at regular intervals.
Ill check that, truck has about 280k miles. If it is a sensor i would expect it would only illuminate the abs light instead of esp and traction control. This is first time i had an issue with a truck that has a esp/yaw rate sensor...maybe they throw codes differently
RE: Component 138
Just trying to thow out there, the obvious stuff to ensure is correct first.
09-22-2021, (Subject: Component 138 )
RE: Component 138
Found the problem, one of the modulator wires had rubbed through and was shorting to ground...
09-23-2021, (Subject: Component 138 )
RE: Component 138
(09-22-2021 )eggtrucks Wrote:  Found the problem, one of the modulator wires had rubbed through and was shorting to ground...
Maybe post a pic or 2 of where it was on the truck for others and for future reference?
09-30-2021, (Subject: Component 138 )
RE: Component 138
I dont have a pic, but it was along left frame rail, wire was rubbing on front drive torque arm
