04-15-2018,
I have a 2017 2350. Would it have steel or ceramic? I'm starting to think I should rebuild it yearly, Cheap insurance.
(04-15-2018 )tree98 Wrote: [ -> ]I have a 2017 2350. Would it have steel or ceramic? I'm starting to think I should rebuild it yearly, Cheap insurance.Cummins started put steel plungers sometime in 2013. You dont have to worry. Just replace them every 400,000miles.
(04-16-2018 )Volvo8873 Wrote: [ -> ]The only thing I need are the fuel lines now. does anybody have the part numbers for them? Also, is there any special brackets that I need? any info would be appreciated As quickserve doesn’t show the two cylinder pump for me.Go to https://parts.cummins.com/#/
(04-16-2018 )snailexpress Wrote: [ -> ](04-16-2018 )Volvo8873 Wrote: [ -> ]The only thing I need are the fuel lines now. does anybody have the part numbers for them? Also, is there any special brackets that I need? any info would be appreciated As quickserve doesn’t show the two cylinder pump for me.Go to https://parts.cummins.com/#/
Engine parts/ Put ESN in search window/ Fuel system
(04-16-2018 )Volvo8873 Wrote: [ -> ]For my 2250 build 2012 it shows 2 cyl pump with all associated brackets and pipes.(04-16-2018 )snailexpress Wrote: [ -> ](04-16-2018 )Volvo8873 Wrote: [ -> ]The only thing I need are the fuel lines now. does anybody have the part numbers for them? Also, is there any special brackets that I need? any info would be appreciated As quickserve doesn’t show the two cylinder pump for me.Go to https://parts.cummins.com/#/
Already did that and comes up showing the three cylinder pump and accesories. Ill head over to the dealer in the morning and see what they have to offer.
