Prostar ac
11-05-2018, (Subject: Prostar ac )
Post: #82
RE: Prostar ac
Going into a small tuperware.
./uploads/201811/post_3119_1541474339_ead7b276c2be79bfcd6469839938e6b7.jpg
./uploads/201811/post_3119_1541474428_256677ecf57945f0b64632ca539a3cf0.jpg
User's Signature: 2011 Prostar Cummins 871
 Thanks given by: Waterloo , Sergiu
11-06-2018, (Subject: Prostar ac )
Post: #83
RE: Prostar ac
Wow, looks pretty good.
11-08-2018, (Subject: Prostar ac )
Post: #84
RE: Prostar ac
for the fan solenoid, am I wiring the arduino relay inline at the red arrow (under the hood)? there's a wire a23a on body controller j5 but don't know if that would work. i don't want to have to pass wires through the firewall if not necessary. thanks
./uploads/201811/post_3119_1541708548_c499b0fbe47b7e57ce59adb6b34d3ec5.jpg
Post: #85
RE: Prostar ac
(11-08-2018 )DosGatos Wrote:  for the fan solenoid, am I wiring the arduino relay inline at the red arrow (under the hood)? there's a wire a23a on body controller j5 but don't know if that would work. i don't want to have to pass wires through the firewall if not necessary. thanks
I wired my engine fan solenoid ground wire through the relay on the board. (post #14: http://rawze.com/forums/showthread.php?t...8#pid15808 ).
 Thanks given by: DosGatos
Post: #86
RE: Prostar ac
sorry. got lost. solenoid/relay. post 14 mentions wiring the clutch ground wire. i took that to mean the air solenoid ground wire. I'll play with it some more in the morning. thanks
./uploads/201811/post_3119_1541730595_3ada802602244c04538f84fcb55450e0.jpg
11-09-2018, (Subject: Prostar ac )
Post: #87
RE: Prostar ac
I misread your post. I have corrected my reply in post#85. Initially thought you were referring to the compresor, not the enigne fan.
11-28-2018, (Subject: Prostar ac )
Post: #88
RE: Prostar ac
2011 Prostar, cm871. Does anyone know the oem part# for the ac compressor? I can't see any markings or numbers on my current compressor and don't want to take it off right now. I'm trying to get the number from the dealer but those bastards won't give it to me, the only thing they would tell me is the price $500 those bastards, lol
Post: #89
RE: Prostar ac
(11-28-2018 )rapidisimo Wrote:  2011 Prostar, cm871. Does anyone know the oem part# for the ac compressor? I can't see any markings or numbers on my current compressor and don't want to take it off right now. I'm trying to get the number from the dealer but those bastards won't give it to me, the only thing they would tell me is the price $500 those bastards, lol
that sounds pricey. Got mine for less than $250 I think a couple years ago.
Post: #90
RE: Prostar ac
Do you know the part# by any chance?
