05-29-2017,
I have a prostar 2011 and i have spent 15000 on just ac work . does any one know the problem every thing is new even the bcm. I need some help
[gist]e1a7e378289bf0a1c48d9ece4d703e63[/gist]
(05-29-2017 )Rvest Wrote: [ -> ]I have a prostar 2011 and i have spent 15000 on just ac work . does any one know the problem every thing is new even the bcm. I need some helpWow 15k just on ac repair?? You need to buy all of the tools and learn how to service it yourself i have a prostar myself and yeah they are a painin the butt, i basically replaced ac compressor,termistors, front expansion valve, the accumulator,the cabin filter i bought the vacuum pump to vacuum the system and check for any leaks in all that i probably spend like 500-600 and the 4 cans of freon i did all that myself now the system blowing cold air, freaking morrons of stealerships some times if not all the time guessing what the problem is and still don't fix the problem sorry to hear that u spend tgat much money with that you could of bought the whole brand new system plus tools,little piece of advice like Rawze says if you can do it yourself there's pleny infirmation on the net or youtube Rawze videos
(05-30-2017 )RTRUCKING48 Wrote: [ -> ](05-29-2017 )Rvest Wrote: [ -> ]I have a prostar 2011 and i have spent 15000 on just ac work . does any one know the problem every thing is new even the bcm. I need some helpWow 15k just on ac repair?? You need to buy all of the tools and learn how to service it yourself i have a prostar myself and yeah they are a painin the butt, i basically replaced ac compressor,termistors, front expansion valve, the accumulator,the cabin filter i bought the vacuum pump to vacuum the system and check for any leaks in all that i probably spend like 500-600 and the 4 cans of freon i did all that myself now the system blowing cold air, freaking morrons of stealerships some times if not all the time guessing what the problem is and still don't fix the problem sorry to hear that u spend tgat much money with that you could of bought the whole brand new system plus tools,little piece of advice like Rawze says if you can do it yourself there's pleny infirmation on the net or youtube Rawze videos
