Prostar ac
05-31-2017, (Subject: Prostar ac )
RE: Prostar ac
It could also be legitimately building too much high side pressure and tripping the switches. in that 30 minutes that it works is the engine fan cycling ever 30 seconds or so? if you have gauges you need to monitor the high and low side pressure while its running and note what the pressure is when it shuts off. also make sure your condenser coil is clean. if the system has been opened it could have gotten debris in it which will clog the expansion valve/orfice causing low low side and high high side pressure. pressure switches could also be bad giving the cab controller the wrong info. unfortunately someone thought they needed to introduce computers to hvac in turn making them an infinite PITA. just my personal opinion. Rawze has plenty more years of experience with the things.
06-20-2017, (Subject: Prostar ac )
RE: Prostar ac
Rawze, I have ordered the 3 items listed to build this but I didn't see the 4th board that is under your aduarino. Is that just a blank wafer board you soldered components too? And is the wiring easily obtained 4pin connectors?
 Thanks given by: jmiles3830
06-21-2017, (Subject: Prostar ac )
RE: Prostar ac
(06-20-2017 )Nilao Wrote:  Rawze, I have ordered the 3 items listed to build this but I didn't see the 4th board that is under your aduarino. Is that just a blank wafer board you soldered components too? And is the wiring easily obtained 4pin connectors?
Just a blank board to solder and socket the arduino to.
RE: Prostar ac
Dont rekon youve got a wiring diagram drawn for that yet?
 Thanks given by: RTRUCKING48
RE: Prostar ac
(06-21-2017 )smorgan87 Wrote:  Dont rekon youve got a wiring diagram drawn for that yet?
I am in mid stroke in re-building the rears for my truck and don't have time for elaboration on this project as of yet. I do plan on following up m ore on this for everyone interested but it will take some time.
As far as wiring diagram, the program has the pins etc. and info in it. All that is needed is to wire up the relays to the fan clutch ground wire through one relay (normally CLOSED) just like when installing a manual fan switch. For the compressor, I used the same on circuit that the cab controller used (normally OPEN relay). The triggers for the relays are going to the arduino. The pressure sensor I simply wired the sensing signal to one of the input pins (defined in the program) with a 330 ohm resistor in series and left the +5v and ground for it attached to the cab controller like it was. I only used the one wire from the pressure sensor to an analog in.
The project is unfinished by a long shot but very functional. I plan on making a better version, a better way to connect it, and better detail so that others can follow it properly but I just have not had time as of yet. Too busy re-building the rears and wiring of my truck, and that alone will likely take me a couple more weeks.
RE: Prostar ac
As far as wiring diagram, the program has the pins etc. and info in it. All that is needed is to wire up the relays to the fan clutch ground wire through one relay (normally CLOSED) just like when installing a manual fan switch. For the compressor, I used the same on circuit that the cab controller used (normally OPEN relay). The triggers for the relays are going to the arduino. The pressure sensor I simply wired the sensing signal to one of the input pins (defined in the program) with a 50k ohm resistor in series and left the +5v and ground for it attached to the cab controller like it was. I only used the one wire from the pressure sensor to an analog in.
I hope you are working on rear ends with camera ON.
If not you are in troubleBig_smile2
RE: Prostar ac
(06-21-2017 )snailexpress Wrote:  I hope you are working on rear ends with camera ON.
Not filming it this time. sorry.
RE: Prostar ac
Ill order the parts and see what i can put together. Good luck with your truck.
06-28-2017, (Subject: Prostar ac )
RE: Prostar ac
okay, when I tried to compile the code you posted above I get these errors
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Christopher Clark\Documents\Arduino\sketch_jun28a\sketch_jun28a.ino: In function 'void setup()':
sketch_jun28a:66: error: 'class SwitchTemplate' has no member named 'Reset'
De_IcerTimer.Reset();
C:\Users\Christopher Clark\Documents\Arduino\sketch_jun28a\sketch_jun28a.ino: In function 'void loop()':
sketch_jun28a:96: error: 'class SwitchTemplate' has no member named 'is_busy'
if(!CompressorSwitch.is_busy() && SystemPressure > MIN_SYSTEM_PRESSURE ){//less than safe pres, not busy and > min pres.
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
