Prostar ac
11-19-2017, (Subject: Prostar ac )
Post: #28
RE: Prostar ac
(11-19-2017 )Nilao Wrote:  Where did you secure the tmp36 at? I would presume on the inside of the coil to keep it out of the air filters way?
on the inside against the condenser core itself with a blob of permatex red. I removed the blower motor to get to it.
BTW: this latest rendition with the temp sensor has been working like a charm for us.
 Thanks given by: Sergiu
11-24-2017, (Subject: Prostar ac )
Post: #29
RE: Prostar ac
opk, new issue upon verification in adurino....I have done something wrong I guess.
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Micro"
C:\Users\Nilao\Documents\Arduino\sketch_jul02a\sketch_jul02a.ino:153:10: warning: ISO C++ forbids declaration of '_T' with no type [-fpermissive]
Post: #30
RE: Prostar ac
(11-24-2017 )Nilao Wrote:  opk, new issue upon verification in adurino....I have done something wrong I guess.
It was the forum software killing some of the formatting. I posted it on github as a gist and hacked the forum sw to allow embedded gist code. copy-paste should work properly now, and if not, then you can go to the gist page to get it.
Post: #31
RE: Prostar ac
Thank you sir, I found a typo in your code. Doubt it affects the functionability of it but I thought I'd point it out
{0x02B5,360}, //about 350psi 693
The about 350 is just a descriptor correct? It has no bearing on the program as the actual code it's looking for is the 0x02B5?
Sorry for the questions but I'm learning this programming as I go
Post: #32
RE: Prostar ac
(11-24-2017 )Nilao Wrote:  Thank you sir, I found a typo in your code. Doubt it affects the functionability of it but I thought I'd point it out
yeah,... look close enough and you might find a few more typos in the comments lol.
12-01-2017, (Subject: Prostar ac )
Post: #33
RE: Prostar ac
Lol, for shits and giggles I hooked up with DLB and my evaporator outlet thermistor says it is 239 degrees outside. This is a new thermistor mind you. Well new 3 months ago. I really need to finish that new a/c controller.
12-02-2017, (Subject: Prostar ac )
Post: #34
RE: Prostar ac
(12-01-2017 )Nilao Wrote:  Lol, for shits and giggles I hooked up with DLB and my evaporator outlet thermistor says it is 239 degrees outside. This is a new thermistor mind you. Well new 3 months ago. I really need to finish that new a/c controller.
That is why I hate those factory components and its cheap thermistors.
Bring it over here and i will help you with it. Just call me to let me know when you plan on stopping by.
Post: #35
RE: Prostar ac
Thanks Rawze. If I make it over there before I get home I will take you up on that
03-03-2018, (Subject: Prostar ac )
Post: #36
RE: Prostar ac
Rawze, did you just slice into the transducer wire or did you cut it and run it solely to the arduino?
