Prostar ac
06-14-2018, (Subject: Prostar ac )
Post: #46
RE: Prostar ac
(06-14-2018 )74bassman Wrote:  They did evac the system. I did replace the high pressure sensor. It doesnt ice up just stops running. I can shut the truck off for 30-45 sec start back up, and it runs.
Does the fan turn on when pressure goes up? I’d also would check the high pressure switch connector for corrosion might be giving that sensor a bad reading.
06-15-2018, (Subject: Prostar ac )
Post: #47
RE: Prostar ac
I can't even get the compressor to turn on, I'll try replacing the expansion valve in a few hours.
Post: #48
RE: Prostar ac
AC is fixed, it was a busted wire in the harness to the high pressure switch. Had to take it to the dealer, they found it with the computer. They charged the system, no die, no nothing. I thought it was cold when I left Rawze's, now I'm freezing water in ice cube trays on the dash.
Post: #49
RE: Prostar ac
The fan does kick on, and runs.
Post: #50
RE: Prostar ac
(06-15-2018 )74bassman Wrote:  The fan does kick on, and runs.
Yep, now compressor and fan both work as they should. That broken wire had the system in a fault situation. Nothing showing up on my end via the in truck diagnostics. But, when the Diamond Logic software was hooked up, it showed Chris right where to look. He fixed the wiring and charged the system, knock on wood it will continue to freeze me out of the cab. One thing I did tell him, was do not put any of that dye in there, he said no problem. My thinking, and experience, is that the dye just gums up the system. Last time I tore this thing apart I think there was three pounds of dye in the system and no R134A. And don't forget to move that ambient temp sensor. Removing the die and moving that sensor are the only things that I have found guarantees ice cold air out of these nightmarish ProStar AC systems.
Post: #51
RE: Prostar ac
I did move the ambient sensor, hut not to the cab yet. There is no die in mine
Post: #52
RE: Prostar ac
The infamous thermistors and the blend door actuators can be setting faults. Also the body controller is monitoring the amp draw from the compressor clutch. You really need DLB to narrow it down.
06-16-2018, (Subject: Prostar ac )
Post: #53
RE: Prostar ac
(06-15-2018 )kmk Wrote:  The infamous thermistors and the blend door actuators can be setting faults. Also the body controller is monitoring the amp draw from the compressor clutch. You really need DLB to narrow it down.
You can test the thermistors with an ohm meter, Rawze has that in his video. BUT, with some things, Diamond Logic (DLB) is necessary to discover issues in this system. I hate going to the dealer, but sometimes it is just less expensive than throwing parts at this ridiculous AC system.
Post: #54
RE: Prostar ac
The chinese sell diamond logic on ebay and there are other sources for it too. Stop relying on stealerships for anything but odd ball parts. Even then i give google a good hard search before I donate money.
