Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
i have the same kit, if i remember it's a AN6 fitting that will work. or jic(same thing) fittings that came with it. just take 1 of the fittings to a hose or farm(ih case JD) dealer they should have what you need.just read through the post its in here somewhere.:)
Not the jic size, the other end that threads into the base. I'm looking to order it online. I don't have the kit yet. I think it might be 3/8?
Nevermind found it. It's 3/8 x 1/2 jic
Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance.
(08-10-2016 )Inderjit Wrote: [ -> ]Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance.
9068-08-18 9068-08-18 | 1/2" JIC Male x M18x1.5 Metric Male w/ seal
$6.24
$5.87
9068-08-14 9068-08-14 | 1/2" JIC Male x M14x1.5 Metric Male w/ seal
$7.05
$6.63
http://www.discounthydraulichose.com/906...p/9068.htm
This is a link to order the fittings online. Cuz fitting may be hard to find in some stores
(08-11-2016 )jimeneztrans84 Wrote: [ -> ] (08-10-2016 )Inderjit Wrote: [ -> ]Hey guys can anyone please tell me which fitting I need for supply line from oil cooler housing labeled number 5 (back in this post) and which fitting I need for return line to side of the oil pan (cm871). I have already ordered the amsoil bypass kit. Thanks in advance.
$6.24
$5.87
$7.05
$6.63
Thanks so much for part numbers. Little more help if you have part number for 90 deg elbow fittings for amsoil filter housing. Thanks again.
2501-08-06 | 1/2" JIC Male x 3/8" NPTF Male Pipe 90°
On the fittings for the engine feed and return make sure you leave the o ring only, take off the washer it comes with.
(04-03-2016 )Rawze Wrote: [ -> ] (04-03-2016 )Waterloo Wrote: [ -> ]For the bypass oil filter, where did you guys put the return line? Back to the oil pan I am assuming? Now, did you drill a hole in the pan or use the drain plug on the passenger side of the motor? Or is there someplace else to attach the oil return line? My motor is in a thousand pieces right now, and I am thinking this would be a good time to install a by pass filter, or at least get the plumbing started.
There are return ports down both sides of the engine just above the oil pan with large hex plugs in them. Just pick one that is convenient.
I have the cheap Amsoil kit.
It is a BMK30 kit. Here is the link...
http://www.amsoil.com/shop/by-product/fi...e=BMK30-EA
The replacement filter is an eaBP-120. They are like $50.00, or $36.00 if you sign up as a dealer.
I also have the oil sampling valve. It screws ritght into the bypass filter kit, and makes it VERY easy to take oil samples. Here is the link...
https://www.amsoil.com/shop/by-product/f...?code=BK30
For Oil sampling, I use these sample kits,... they are pre-paid...
http://www.amsoil.com/shop/by-product/ot...e=KIT14-EA
Here is a pic of mine. It is mounted on the passenger side right behind my fuel tank with a aluminum plate and some "J" bolts from home depot. No holes were drilled into the frame at all. The filter lasts about 60 - 80k miles at a time.
Hey Rawze can I get part number the for the fitting at the inlet port of filter housing? Not the elbow but the other with a bend on it.
